May 20th, 2024, 11:24pm
Procedural Simultaneous Statement (Read 5838 times)
Daniel_Platte
Munich/Germany
Jan 03rd, 2007, 8:39am
Hi all!
The VHDL-AMS language provides a feature "Procedural Simultaneous Statement" that is basically the same as Verilog-AMS's "Procedural Assignment". Unfortunately, AMS Designer and ADvance MS do not support the procedural simultaneous statement  :'(.
Example (from a diode model):
--------------------------------------- BEGIN CODE SNIPPET --------------------------------------------------------
PROCEDURAL IS BEGIN
   VD := VIN-VOUT-IIN*RS/AREA;
   ID := GMIN*VD+AREA*(ISS*(-1.0+exp(0.181069E-2*VD*Q/K))-IBV*exp((-0.333167E-2)*(BV+VD)*
Q/K));
   CJ := AREA*CJO*iffunc1(VD);
END PROCEDURAL;
--------------------------------------- END CODE SNIPPET --------------------------------------------------------
The VHDL-AMS committee proposes to model this by using analog functions like this:
TYPE QR IS RECORD
   VDv : REAL;
   IDv : REAL;
   CJv : REAL;
 END RECORD;
 FUNCTION proceqs(
   VINi   : REAL;
   IINi   : REAL;
   VOUTi  : REAL;
   IOUTi  : REAL;
   VDi    : REAL;
   IDi    : REAL;
   CJi    : REAL;
   dIDdti : REAL;
   dVDdti : REAL
 ) RETURN QR IS
    VARIABLE VINv   : REAL := VINi;
    VARIABLE IINv   : REAL := IINi;
    VARIABLE VOUTv  : REAL := VOUTi;
    VARIABLE IOUTv  : REAL := IOUTi;
    VARIABLE VDv    : REAL := VDi;
    VARIABLE IDv    : REAL := IDi;
    VARIABLE CJv    : REAL := CJi;
    VARIABLE dIDdtv : REAL := dIDdti;
    VARIABLE dVDdtv : REAL := dVDdti;
 BEGIN
   VDv := VINv-VOUTv-IINv*RS/AREA;
   IDv := GMIN*VDv+AREA*(ISS*(-1.0+exp(0.181069E-2*VDv*Q/K))-IBV*exp((-0.333167E-2)*(BV+VD
v)*Q/K));
   CJv := AREA*CJO*iffunc1(VDv);
   RETURN (vdv, idv, cjv);
 END;
 (VD, ID, CJ) == proceqs(VIN, IIN, VOUT, IOUT, VD, ID, CJ, dIDdt, dVDdt) TOLERANCE "Current";
Unfortunately, the topology checker of AMS Designer counts this simultaneous statement as one equation (instead of three) and refuses to simulate the model...
Does anyone have experience how to work-around this problem? Are there simulators supporting the proc. sim. stat. or plans to realize the language construct?
Thanks in advance for any help.
Cheers,
Daniel
P.S. Complete VHDL-AMS code is attached
Re: Procedural Simultaneous Statement
Reply #1 - Jan 4th, 2007, 11:16am
I'm not an expert in VHDL, but: shouldn't the model compute charge rather than capacitance?
 -ID-0.115E-7*dIDdt+IIN-CJ*dVDdt == 0.0 TOLERANCE "Current";
Daniel_Platte
Munich/Germany
Reply #2 - Jan 5th, 2007, 12:53am
You're right, charge conservation is not ensured within the posted model. Anyway, the diode model only provides the basis for my question on the VHDL-AMS realization of proc. statements. Is anyone using VHDL-AMS for device modeling purposes?
Reply #3 - Jan 18th, 2007, 4:25am
Daniel_Platte wrote on Jan 5th, 2007, 12:53am:
I hope not!  I've been presenting tutorials on why Verilog-A is the right language for device modeling. Smiley
Seriously, though, there were a few groups that used to; some of them were connected with Prof C-J Richard Shi at U. Washington, whose MCAST model compiler would convert "VHDL-A" models into Spice C code.  (Note that "VHDL-A" isn't a standard, and I guess is defined in some sense by what MCAST can do ...)
abhi_kolpekwar
Reply #4 - Jan 18th, 2007, 2:59pm
+ Unfortunately, the topology checker of AMS Designer counts this simultaneous statement as one equation (instead of three) and refuses to simulate the model...
I am assuming you are refering to a compile time error about solvability check. You can use a ncvhdl option "-nosolvecheck" to get around this error. This disables the solvability check by the compiler.
AMS designer support user defined functions to help write device models. However, it does not support analog records yet. Your example uses analog records.
