mohammadreza
If I am alright with the way I am measuring my Kf, then I should say that the problem is solved like this.
In order to get rid of the frequency resonance of the BFL and BFC, I should use one of the inductors of the pi matching network connected to vdd instead of the ground, which provides dc connection required as well.
Then, when I did this, I faced that for lower input amplitudes, the output is damped. but I had good results in the pss analysis. then, there must have been another powerful oscilation as well. checking the effect of the bypass capacitance on the Kf, it shouldn't be very big. so, by decreasing that capacitance, another implicit resonance factor that damped my output for lower inputs is removed.
thanks for notifying me about the Kf. just please let me know if I have to take care of anything in my simulation configurations.
