Apr 20th, 2024, 9:23am
How can I conver config view in an amsd block (Read 2087 times)
AMS_ei
Mar 18th, 2017, 10:26pm
I have a big config view in my ams setup in the gui mode. Now, I want to run the same config view in the irun command.
How can I convert a config view into an amsd block? Is there any automated script for that in cadence?
Thank you.
Kind regards,
Re: How can I conver config view in an amsd block
Reply #1 - Mar 20th, 2017, 8:12am
Probably the simplest approach is to use the runams command to netlist and run the simulation. This will then create the various files you need (you can choose to run the simulation or not).
AMS_ei
Reply #2 - Apr 19th, 2017, 4:01pm
Thank you, Andrew.
