Verilog-AMS
Analysis
Modeling
Design
Theory
Books
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 9
th
, 2010, 6:19pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Lookup Table - Voltage in/ Voltage Out - SPECTRE
Previous topic
Next topic
Lookup Table - Voltage in/ Voltage Out - SPECTRE (Read 158 times)
kevinvinv
Jul 30
th
, 2010, 4:05pm
What would be the best way for me to implement a voltage in, voltage out lookup table in spectre?
__________________
Kevin
IP Logged
Re: Lookup Table - Voltage in/ Voltage Out - SPECTRE
Reply #1 -
Jul 30
th
, 2010, 7:30pm
Kevininv,
Use the Verilog-A table model.
IP Logged
kevinvinv
Reply #2 -
Jul 31
st
, 2010, 11:36am
I was hoping for something other than Verilog A... Simulating without verilog-A is like living life without a stomach ache. Almost every time I have convergence issues- I trace it to a verilogA block. Anyhow- if that is my only option- I guess I'll give it a go.
Thanks!
__________________
Kevin
IP Logged
Reply #3 -
Aug 3
rd
, 2010, 5:16am
trace it to a ... poorly-written? ... verilogA block?
There are lots of examples of poorly-written Verilog-A modules here. You do sort of need a basic understanding of the mechanics of Spice -- Newton-Raphson, so the module had better have continuous derivatives, etc.
Be careful when you build your $table_model -- some splines can give strange values when extrapolating, or even when interpolating, such that the Newton solver will get confused.
IP Logged
kevinvinv
Reply #4 -
Aug 3
rd
, 2010, 5:33am
You know I've heard that "You just need to write it correctly" sort of thing. I've written a lot of VerilogA. I've used examples from the Cadence ahdl Lib unmodified, I've read books and taken classes. Bottom line- it more often than not is the cause of my convergence problems. I have MUCH better luck using analogLib components to model behavior.
I suppose I am still doing something wrong
Thanks for the comments! I appreciate it!
I got my table model working- did indeed see strange interpolation but when I switched to order "1" - I got what I wanted- just standard PWL.
Thanks again!
__________________
Kevin
IP Logged
The Spectre
San Jose
Reply #5 -
Aug 3
rd
, 2010, 11:04am
Kevin,
There are a series of very common mistakes that people make with Verilog-A that tend to cause most of the problems. Once you understand the language well enough not to make those, life with Verilog-A gets much easier. Next time Verilog-A causes you grief, consider posting your model to this forum. Perhaps we can point out your mistake.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Opportunities
What's New
Links
Experts
Perspective
Submissions
Calculator
Trouble viewing this site?
Copyright © 2002-2009
Designer's Guide Consulting
Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Community
Web
Advertise on this site.
Give back to the Designer's Guide Community by shopping at
Amazon
. Purchasing products through this link helps to fund our activities and does not increase your cost.
