Verilog-AMS
Analysis
Modeling
Design
Theory
Books
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 8
th
, 2010, 1:22am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› could damping factor >>1
Previous topic
Next topic
could damping factor >>1 (Read 145 times)
casual
Jul 29
th
, 2010, 10:35pm
For a over-damped pll system, the zeta (damping factor) must be >> 1.
I checked the damping factor formula (Cartesian plane), it shows zeta=wn*cos(theta)/wn = cos(theta), which is bounded by +1,-1 from mathematics aspect.
could zeta/damping factor >>1?
IP Logged
raja.cedt
Re: could damping factor >>1
Reply #1 -
Jul 30
th
, 2010, 10:51pm
hello,
when you are saying damping factor is cos function you are assuming that pole are on complex plane, so damping factor is between 0 to 1. If pole are on the real axis then damping factor will be more than one. So your cos formula don't catch this one.
Assume you have poles at A+JB and A-jB so total equation is S^2+2AS+A^2+B^2, so damping factor is A/(sqrt(a^2+B^2)..so geta is cos function.
when they are on the real axis this equation is not correct.
Hope you got the point.
Rajasekhar.
IP Logged
casual
Reply #2 -
Jul 30
th
, 2010, 10:57pm
yup, it is same as what I assumed.
So the cos(theta) formula is only applicable until critical damped pll when zeta=1.
any other comments?
IP Logged
raja.cedt
Reply #3 -
Jul 31
st
, 2010, 1:17am
yes...or you can say if poles are in complex plane only
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Opportunities
What's New
Links
Experts
Perspective
Submissions
Calculator
Trouble viewing this site?
Copyright © 2002-2009
Designer's Guide Consulting
Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Community
Web
Advertise on this site.
Give back to the Designer's Guide Community by shopping at
Amazon
. Purchasing products through this link helps to fund our activities and does not increase your cost.
