Verilog-AMS
Analysis
Modeling
Design
Theory
Books
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 8
th
, 2010, 1:31am
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› Cadence Convergence Error
Previous topic
Next topic
Cadence Convergence Error (Read 191 times)
mohammadreza
Jul 27
th
, 2010, 4:25am
I am simulating an RF Power Amplifier in Cadence, SpectreRF environment. I am controlling the supply current by a seperate voltage applied to a transistor. For some values that I choose, I face with convergence error, both in PSS and Transient. However, when I remove my mathcihng network and replace it by a real load value that I had designed, I face no errors.
Is there any way for setting the options correctly so that I don't lose accuracy and have my expected result? I have tried the Moderate and ven liberal presets but the moderate one faces error as well and the liberal one is completely away.
IP Logged
mohammadreza
Re: Cadence Convergence Error
Reply #1 -
Jul 27
th
, 2010, 5:08am
Thanks, I didn't see any HB-engine. Just shooting and flexible balance. I chose flexible balance and it worked.
About the Q, since I need to operate between 2.4GHz and 2.49GHz, I chose 300. Is that fine?
thanks
IP Logged
mohammadreza
Reply #2 -
Jul 27
th
, 2010, 5:29am
thanks!
decreasing the Q helped run the simulation successfully with the moderate accuracy.
IP Logged
Reply #3 -
Jul 27
th
, 2010, 7:16am
pancho_hideboo wrote
on Jul 27
th
, 2010, 4:30am:
Maybe your matching network has very high Q.
High Q could cause convergence failure for time domain solver.
Use HB-engine not Shooting-Newton-engine in PSS of Cadence Spectre.
mohammadreza wrote
on Jul 27
th
, 2010, 5:08am:
See
http://www.designers-guide.org/Forum/YaBB.pl?num=1258711290/1#1
mohammadreza wrote
on Jul 27
th
, 2010, 5:08am:
Is that fine?
BW
3dB
=f0/Q=2.445GHz/300=8.15MHz. It is too narrow.
You have to have broad BW
3dB
which is far broader than 90MHz.
So set Q lesser than 27.
Also see the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1207009725/2#2
http://www.designers-guide.org/Forum/YaBB.pl?num=1278414763/18#18
mohammadreza wrote
on Jul 27
th
, 2010, 5:29am:
Your case summaries are followings.
For Q>=300
Shooting-Newton-PSS
with accuracy of moderate
can not converge
For Q<30, Shooting-Newton-PSS with accuracy of moderate can converge.
For Q>=300
HB-PSS
can converge
For Q<30, HB-PSS with accuracy of moderate can converge.
Are the aboves correct ?
Last Edit: Jul 28
th
, 2010, 6:28am by pancho_hideboo
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
mohammadreza
Reply #4 -
Jul 28
th
, 2010, 5:41am
Yes, that's right
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Opportunities
What's New
Links
Experts
Perspective
Submissions
Calculator
Trouble viewing this site?
Copyright © 2002-2009
Designer's Guide Consulting
Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Community
Web
Advertise on this site.
Give back to the Designer's Guide Community by shopping at
Amazon
. Purchasing products through this link helps to fund our activities and does not increase your cost.
