Welcome, Guest. Please Login or Register. Please follow the Forum guidelines. Sep 9th, 2010, 5:37pm
  HomeHelpSearchLoginRegisterPM to admin
PLL transfer function plot (Read 315 times)
casual
Jul 27th, 2010, 12:19am
Can cadence spectreRF plot out the PLL transfer function?
Re: PLL transfer function plot
Reply #1 - Jul 27th, 2010, 4:57am
Casual,
   Can you be more specific about what you would like to do? Do you
mean plot a transfer function? Do you mean simulate a PLL and
generate a transfer function? Which transfer function are you looking
to plot? BTW, I believe that vendor specific questions go in the
simulators section.
View Profile schaldenbrand3   IP Logged
casual
Reply #2 - Jul 27th, 2010, 5:50am
I would like to obtain   input/output transfer function of a PLL, eg: H(jw) vs freq and check bandwidth & overshoot response. I can make it in matlab but I do not know how to generate it in spectre. I believe it can be simulated.
PS: thx for reminding me that this post should be in simulator session. I do not know how to move it to there.
vp1953
Reply #3 - Jul 27th, 2010, 10:21am
Hi Casual,
I was told by one of the Cadence technologists that anything that can be done in Matlab can also be done in Spectre, perhaps not so conveniently. Here might be one way - model the PD (and the VCO as well as the divider) using verilog-ams, the loop filter could be used as a circuit block. The use stability analysis (analysis>stb) for gain and phase plots - this option requires placing a probe somewhere in the feedback loop.
If you do find an easier way, do let us know.
casual
Reply #4 - Jul 28th, 2010, 12:02am
i know verilogA can model the laplace function. The results will be the same as in matlab. But it depends on how accurate we model it. Therefore it is great if we could simulate directly the PLL to get the transfer function.
Reply #5 - Jul 28th, 2010, 10:30pm
Casual,
  Look in samples/pllLib for examples of how to implement phase
domain models for a PLL.
casual
Reply #6 - Jul 30th, 2010, 11:00pm
thx, i will take a look
Reply #7 - Aug 7th, 2010, 3:50am
If you can build "State Averaged Model" for target DUT, you can adopt conventional AC Analysis in any SPICE type Simulator.
See http://edocs.soco.agilent.com/display/ads2009/Open+and+Closed+Loop+Simulation+of...
Here all blocks are treated as linear state averaged model.
      "LinearVCO" is a linear model of a VCO.
      "LinearPFD" is a linear model of a phase/frequency detector.
      "LinearPFD2" is a 2-input linear model of a phase/frequency detector.
      "LinearDivider" is a linear model of a divider.
This "State Averaged Modeling" is well known as "Describing Function Method" or "Equivalent Transfer Function Method"
in Nonlinear Control Theory.
Equivalent Lowpass Model of RF Bandpass System is this "State Averaged Modeling".
Phase Domain Model of PLL is also this "State Averaged Modeling".
http://www.designers-guide.org/Forum/YaBB.pl?num=1237145096/8#8
The Spectre
San Jose
Reply #8 - Aug 7th, 2010, 12:57pm
It is still not clear what you want to do. It is possible to build a phase-domain model of your PLL and simulate in any simulator that has a reasonable modeling language, including any circuit simulator that implements Verilog-A. You could also use tools like Matlab. Or you can code the model up your self in any programming language, such as Python or C. However, this is a simplified model; very simplified as you will come to understand when you go to build the models of the various components. This process is described in some depth in http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf.
Alternatively, you might be looking to do a transistor-level simulation and extract the transfer function. That is possible with RF simulators such as SpectreRF. Basically, you set up the PSS analysis so that its initial transient interval (set by tstab) is long enough to take the PLL into lock, then it computes the periodic steady-state solution. For this to be possible your PLL must satisfy a few criteria. First, it must have a periodic steady-state solution; so your PLL must have no deadzone or fractional-N architectures. And it must be practical to compute the steady-state solution, and so if there is a divider in the loop, its divide ratio must be relatively small. Once you have the steady-state solution, you can run any of the small-signal analyses that work with PSS. Those include PAC, PXF, PSTB, and of course, PNoise. They perform the AC, transfer function, stability, and noise analyses respectively.
Trouble viewing this site? Copyright © 2002-2009 Designer's Guide Consulting. 'Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Give back to the Designer's Guide Community by shopping at Amazon. Purchasing products through this link helps to fund our activities and does not increase your cost.
