Verilog-AMS
Analysis
Modeling
Design
Theory
Books
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 8
th
, 2010, 1:26am
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› LNA + mixer weird conversion gain from spectre
Previous topic
Next topic
LNA + mixer weird conversion gain from spectre (Read 104 times)
.matteo
Padova, Italy
Jul 26
th
, 2010, 11:12pm
Hi everybody!
I'm calculating the conversion gain of a LNA+gm+current mixer chain in a direct conversion receiver. I'm using spectreRF and PSS (tstab 5n, shooting engine, no additional options). I do a parametric sweep on the rf frequency and I set the rf frequency equal to the lo frequency through a variable. I use the same variable as beat freq. in the pss.
I get the weird conversion gain of the figure I uploaded.
Any suggestion about how to solve this problem?
.mat
IP Logged
RFICDUDE
Re: LNA + mixer weird conversion gain from spectre
Reply #1 -
Jul 27
th
, 2010, 4:13am
I think the problem is that the phase difference between the input signal and the LO, at the mixer, will determine the amplitude of the DC output mixing product. If you have a transmission line (or delay) somewhere between the input port and mixer then the phase difference will be a function of frequency. This is why you see periodic nulls and broad peaks close to your expected conversion gain (I assume).
If the input signal was offset from the LO then the phase difference would not matter other than to cause some proportional phase shift to the output frequency tone, but for the DC mixing product the output must be a constant and is proportional to the cosine of the phase difference.
I think you'll simply need to use a different analysis option to skirt around the issue. One possibility is to use PSS and PAC analysis which will let you sweep the conversion gain for individual LO frequencies. Other options include QPSS with the input signal being the moderate level tone or envelope simulation (but envelope is a bit more complicated to set up).
I will be interested in hearing if others have solutions for synchronizing the LO to the mixer input signal.
IP Logged
Reply #2 -
Jul 27
th
, 2010, 4:31am
Take care of both I and Q outputs of mixer.
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Opportunities
What's New
Links
Experts
Perspective
Submissions
Calculator
Trouble viewing this site?
Copyright © 2002-2009
Designer's Guide Consulting
Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Community
Web
Advertise on this site.
Give back to the Designer's Guide Community by shopping at
Amazon
. Purchasing products through this link helps to fund our activities and does not increase your cost.
