Welcome, Guest. Please Login or Register. Please follow the Forum guidelines. Sep 8th, 2010, 1:17am
  HomeHelpSearchLoginRegisterPM to admin
Noise of an SC integrator with PSS and PNOISE.. (Read 80 times)
jefkat
Jul 26th, 2010, 8:58am
Hi ,
   I am simulating a fully diff Switched Cap Integrator. The input sample caps are 1p each. The amplifier has Adc=50dB,f3db=160KHz and the input reffered PSD of 1f /Hz. My clock frequency is 2MHz.
    I did a PSS + PNOISE to get the input reffered totoal noise. My PSS
beat freq=2M
N harmmonics=100
Facmax= 250M
My PNOISE has  sweep range of 1 to 2M. Reference side band is 0 ofcourse. Noise type is "sources" .
When I run the sim my total input referred noise power (intgrated from 1 to 1MHz) is 90n (much higher than I expect).
I also have a noise less model of my op amp and when that is used in the sim instead of the real amp then the input referred noise power is just what you expect from 1pF sampling caps ( ~16n).
Could anyone please give me some suggestion?
thanks much
shaf
Trouble viewing this site? Copyright © 2002-2009 Designer's Guide Consulting. 'Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Give back to the Designer's Guide Community by shopping at Amazon. Purchasing products through this link helps to fund our activities and does not increase your cost.
