Welcome, Guest. Please Login or Register. Please follow the Forum guidelines. Sep 9th, 2010, 6:13pm
  HomeHelpSearchLoginRegisterPM to admin
What does this mean in ADS --> S[1::2,1::2] (Read 288 times)
DoYouLinux
Jul 17th, 2010, 9:51am
Hi everyone,
I am trying to study about S parameters in ADS. I have seen from a file that in the "stoy" function, there is a variable defined in Mea Eqn as follows:
Param_y = stoy(S[1::2,1::2]).
In the schematic, there is an element called "S2P" driven by two ports Port 1 and Port 2. I guess that this is to transform S paramters to Y parameters. But, what does the syntax
S[1::2, 1::2] mean ?
Could someone explain to me please ?
Thank you very much,
DYL
Re: What does this mean in ADS --> S[1::2,1::2]
Reply #1 - Jul 18th, 2010, 3:12am
RFICDUDE
Reply #2 - Jul 18th, 2010, 4:02pm
Pancho's link explains what the notation means, but if you want to know a simple way to use the stoy function just use (I think)
stoy(S)
or if you prefer or need z-parameters
stoz(S)
these functions will save the y and z parameter equivalent results for each s-parameter analysis simulation (all ports).
The wildcard and sequence notation would be useful if you are only interested in doing a conversion for some select ports (I think).
I use these functions when I'm interested in calculating the either the series or shunt effective lumped element equivalent resistance, capacitance and/or inductance over frequency.
Reply #3 - Jul 26th, 2010, 4:57am
"[]", "()" and "{}" have completely different meanings each other in Agilent ADS Post Processing Environment.
S parameters are matrix, here you have to use "()" not "[]".
Usually sequence operator, "::" is used for Array not Matrix.
And if we use sequence operators for two-dimensional Array or Matrix, an applied indexing order such as "Row-Major" or "Colum-Major" is ambiguous.
So I confirmed validity of  sequence operator, "::" for two-dimensional Matrix.
It seems an indexing is "Row-Major" as same as C-language.
DoYouLinux
Reply #4 - Jul 26th, 2010, 6:57am
Hi RFDUDE,
Thank you very much for your explanation.
DYL
DoYouLinux
Reply #5 - Jul 26th, 2010, 7:10am
Hi pancho_hideboo,
Thank you very much for your answer. I actually used S(1::2,1::2) in my simulation, not S[1::2,1::2]. I have some further questions regarding your simulation:
1) How did you generate the input S parameters ( S(1,1) = 11+j0, S(1,2) = 12+j0, ...) ?
2) What is the main difference between using S(3::4,3::4) and S{{S33,S34},{S43,S44}} ? I think the result should be the same.
Thank you in advance  :)
DYL
DoYouLinux
Reply #6 - Jul 26th, 2010, 7:23am
Ah, my fault, I mean comparison between S(3::4,3::4) and {{S33,S34},{S43,S44}}, the result should be the same.
DYL
Reply #7 - Jul 26th, 2010, 8:24pm
DoYouLinux wrote on Jul 26th, 2010, 7:10am:
See attached figure.
http://edocs.soco.agilent.com/display/ads2009/S1P+Eqn+to+S6P+Eqn+%281-+to+6-Port...
2) What is the main difference between using S(3::4,3::4) and {{S33,S34},{S43,S44}} ?
Right.
DoYouLinux
Reply #8 - Jul 27th, 2010, 6:29pm
Hi pancho_hideboo,
Thank you very much for your reply. This is my another new knowledge about ADS.
DYL
Trouble viewing this site? Copyright © 2002-2009 Designer's Guide Consulting. 'Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Give back to the Designer's Guide Community by shopping at Amazon. Purchasing products through this link helps to fund our activities and does not increase your cost.
