Verilog-AMS
Analysis
Modeling
Design
Theory
Books
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 8
th
, 2010, 1:07am
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› Linearity Sims
Previous topic
Next topic
Linearity Sims (Read 188 times)
Mayank
Linearity Sims
Jun 21
st
, 2010, 9:18pm
If i want to check the linearity of my opamp, how do i determine what sims of the following or otherwise should i conduct ??
THD / Rapid IP3 / IM3 / IM2 / IM5 ??
IP Logged
Re: Linearity Sims
Reply #1 -
Jun 24
th
, 2010, 5:52am
Mayank wrote
on Jun 21
st
, 2010, 9:18pm:
It depends on application of OPAmp.
But THD and IP3 are enough for metrics of linearity generally, although I don't know what you mean by "Rapid IP3".
IP2(IM2) have various type. On the other hand IP3(IM3) definition is unique.
What type of IP2(IM2) do you intend to evaluate ?
See
http://www.designers-guide.org/Forum/YaBB.pl?num=1262010975/1#1
Also see
http://www.designers-guide.org/Forum/YaBB.pl?num=1264434513/1#1
Last Edit: Jun 25
th
, 2010, 4:44am by pancho_hideboo
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
Re: Linearity Sims
Reply #2 -
Jun 24
th
, 2010, 7:48am
Mayank,
If you mean Spectre RF Rapid IP3 analysis then it is really a
analysis rather than a measurement. It is probably better used
as a tool to
1) Debug where there is distortion in the design, along with the
distortion summary
2) Identify the "worst-case" corners to investigate when you have a
lot of corner conditions. Or the Monte Carlo seeds[runs] to
investigate
I would probably add Spurious Free Dynamic Range to the list of
measurements, if the target application is for data converters. One
other thing to consider for your list is test frequencies, loads, etc.
to be used for characterization.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Opportunities
What's New
Links
Experts
Perspective
Submissions
Calculator
Trouble viewing this site?
Copyright © 2002-2009
Designer's Guide Consulting
Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Community
Web
Advertise on this site.
Give back to the Designer's Guide Community by shopping at
Amazon
. Purchasing products through this link helps to fund our activities and does not increase your cost.
