Welcome, Guest. Please Login or Register. Please follow the Forum guidelines. Sep 9th, 2010, 6:26pm
  HomeHelpSearchLoginRegisterPM to admin
problems of sc filter (Read 119 times)
adelezy
Jun 17th, 2010, 7:44pm
Hi, All
I simulated one sixth-order elliptical Low-Pass SC Filter.
The example that I used is <Demystifying Switched-Capacitor Circuits>  MingLiang Liu P101
In the  circuit, ideal opamps and switches  are used.
OP's gain, UGBW and slew rate was considered and checked.
The switches' on resistor is set to 1ohm.
PAC simulation result is that 0db in pass band and w-3db is also right, but probelm exists in tran analysis.
The amplitude of sine wave is much smaller than input, and the output attenuation is about -5db.
The other problem is that output wave is like saw wave, not sine wave.
Thank you.
Mayank
Re: problems of sc filter
Reply #1 - Jun 17th, 2010, 9:02pm
Are you using the same termination as you were using while doing PAC analysis ??
Is the Opamp Slewing instead of linear settling ?
Trouble viewing this site? Copyright © 2002-2009 Designer's Guide Consulting. 'Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Give back to the Designer's Guide Community by shopping at Amazon. Purchasing products through this link helps to fund our activities and does not increase your cost.
