Verilog-AMS
Analysis
Modeling
Design
Theory
Books
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 8
th
, 2010, 1:06am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› phase noise increase due to FD-to-SE converter
Previous topic
Next topic
phase noise increase due to FD-to-SE converter (Read 324 times)
OpAmp
Jun 17
th
, 2010, 3:05pm
I have designed a fully differential (FD) ring oscillator. It has a fairly decent phase noise. I need to convert the FD output of the oscillator to singe-ended (SE). When I use a simple diff pair to do that the phase noise at high frequencies degrades considerably. In other words, the phase noise at the output of the oscillator (input of the FD-to-SE is still good), but the phase noise at the output of the FD-to-SE converter is not good at high frequencies.
I was wondering is there a good FD-to-SE converter which does not add much phase noise/jitter?
IP Logged
Mayank
Re: phase noise increase due to FD-to-SE converter
Reply #1 -
Jun 17
th
, 2010, 9:05pm
Do not use Tail Current Source. Keep sizes large.
--M
IP Logged
rfcooltools.com
Reply #2 -
Jun 18
th
, 2010, 11:50am
OpAmp,
Use a totem pole circuit sometimes called push-pull output driver.
http://rfcooltools.com
IP Logged
love_analog
Reply #3 -
Jul 29
th
, 2010, 6:34am
Mayank, rfctools
Why does the OP's phase noise degrade. I would have thought since its outside the VCO loop, the noise is just going to raise the thermal noise floor rather than get integrated. I am curious to see if I am right.
BTW, how do your solutions help.
IP Logged
Mayank
Reply #4 -
Jul 29
th
, 2010, 9:15pm
Any extra circuitry you add is gonna inject its own noise. Hence, phase noise of the signal coming from VCO is bound to increase.
The noise neednt be just thermal. The circuit's flicker noise will also gt injected into the system, which is not getting affected by preceding PLL's XF. Hence, unmodulated noise(both flicker n thermal) get added to the signal, thus degrading phase noise.
If by integration, you mean converting freq. signal to phase, then that you would have to do at FD-SE converter's output too.
No TCS means no flicker upconversion. Hence lower phase noise. Large sizes keep flicker from i/p pairs in control.
--M
IP Logged
vp1953
Reply #5 -
Jul 30
th
, 2010, 9:53am
Hi Mayank,
Is the mechanism for flicker up conversion due to the inherent non linearity of the diff amp?
IP Logged
Mayank
Reply #6 -
Aug 3
rd
, 2010, 4:08am
No, the mechanism involved is the differential pulling of Tail current source node at twice the freq. of the applied diff. signal.
Non-linearity of diff. pair, imperfect differential signal, finite rout of TCS, CM fluctuations, gm mismatch b/w i/p pairs etc. contribute to the total noise because of upconversion from above mentioned phenomenon.
IP Logged
Reply #7 -
Aug 3
rd
, 2010, 8:29pm
Mayank,
Unless OpAmp is doing Monte Carlo simulations including mismatch,
then the imperfections in the differential signal path will not be
manifested unless they are related to unmatched loading. Are there
other potential sources for flicker noise conversion?
IP Logged
Mayank
Reply #8 -
Aug 3
rd
, 2010, 8:55pm
Yes there is, the prime source -- Flicker noise from Tail current source.
All the other ones i mentioned were to indicate that the secondary sources like diffamp non-linearity et al. that vp1953 was suggesting are contributors, not phenomenon which leads to upconversion.
Flicker noise of TCS upconverts increases phase noise.
IP Logged
vp1953
Reply #9 -
Aug 5
th
, 2010, 11:26am
Hi Mayank,
Thanks for sharing your great insights.
Obviously if the input signals at the diff amp were small, then the drain of the tail current source is a virtual ground, there would not be any 2f component there.
For the case, that the input signals are large, assume that each FET of the diff acts like a switch. For this case, there would be a 2f component at the drain. But the 2f component is additive to the flicker noise and not multiplicative, so you would still need some nonlinearity for the flicker noise to upconvert to the 2f frequency.
At each single ended output of the diff amp, the flicker noise of the tail source is modulated by f (square wave with amplitude 1,0 assuming the FET of the input acts as a switch). The differential output has the flicker noise modulated by f (square wave with amplitude 1,-1). Short of any non ideality present, the upconversion of the flicker noise is to f, not to 2f.
I look forward to any comments you can provide.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Opportunities
What's New
Links
Experts
Perspective
Submissions
Calculator
Trouble viewing this site?
Copyright © 2002-2009
Designer's Guide Consulting
Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Community
Web
Advertise on this site.
Give back to the Designer's Guide Community by shopping at
Amazon
. Purchasing products through this link helps to fund our activities and does not increase your cost.
