Welcome, Guest. Please Login or Register. Please follow the Forum guidelines. Sep 8th, 2010, 12:33am
  HomeHelpSearchLoginRegisterPM to admin
Pages: 1 2 3
How to plot "input reflection coefficient" in ADS (Read 2765 times)
Re: How to plot "input reflection coefficient" in ADS
Reply #30 - May 29th, 2010, 1:00am
DoYouLinux wrote on May 27th, 2010, 6:43am:
After I repeat the simulation in ADS again, I got correct results.
Have you truely come to be able to understand calculation of "Γin_corrected" in Case-2 without using "stos()" ?
[Case-1]
S_Z01_ZL=stos(S_Z01_Z02, {Z01,Z02}, {Z01,ZL})
S_Z01_ZL(1,1) == Γin=(Zin-conj(Z01))/(Zin+Z01)
[Case-2]
S_Zs_ZL=stos(S_Z01_Z02, {Z01,Z02}, {Zs,ZL})
S_Zs_ZL(1,1) != Γin=(Zin-conj(Z01))/(Zin+Z01)
S_Zs_ZL(1,1) == Γin_corrected=(Zin-conj(Zs))/(Zin+Zs)
« Last Edit: May 29th, 2010, 2:30am by pancho_hideboo »
DoYouLinux
Reply #31 - Jul 24th, 2010, 9:19am
Hi pancho_hideboo,
I tried to evaluate input and output reflection coefficients in several ways, including Case 2 you mentioned. The results I obtained are all the same, as shown in the attached figures. If you have more comments, please post again. Thank you very much for your clear explanations, you are a great sensei.
DYL
DoYouLinux
Reply #32 - Jul 24th, 2010, 9:25am
and the results ...
Pages: 1 2 3
Trouble viewing this site? Copyright © 2002-2009 Designer's Guide Consulting. 'Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Give back to the Designer's Guide Community by shopping at Amazon. Purchasing products through this link helps to fund our activities and does not increase your cost.
