Welcome, Guest. Please Login or Register. Please follow the Forum guidelines. Sep 9th, 2010, 7:04pm
  HomeHelpSearchLoginRegisterPM to admin
pole zero doublet in regulator (Read 845 times)
raja.cedt
Jan 23rd, 2010, 1:03am
hi,
   I am designing a simple regulator with nmos input opamp and pmos pass transistor o/p stage. I am getting a pole zero doublet near 100hz.I am attaching both ckt as well as bode plot,so please let me know your thoughts.
Rajasekhar.
raja.cedt
Re: pole zero doublet in regulator
Reply #1 - Jan 23rd, 2010, 1:07am
here is the plot.
thechopper
Reply #2 - Jan 25th, 2010, 4:19pm
Hi Rajasekhar,
What is your regulated voltage level? Is your pass transistor working in triode mode?
One possibility is the capacitance difference between the two branches of the differential pair helping create such doublet.
Best
Tosei
Keep it simple
raja.cedt
Reply #3 - Jan 25th, 2010, 8:40pm
hi tosei,
           tx for your reply. This regulator has designed for 1.2 with .8 reference voltage. You mean the cap at the drains of the diff pair transistors? i didn't understand how they will give,in fact i did many regulators of this sort i didn't see any doublet. What i am thinking is at the first stage o/p i have kept rc seris compensation network, parallel to that pass transistor Cgs is there, i feel this may be the culprit. any how please explain this.
rajasekhar.
vivkr
Reply #4 - Jan 25th, 2010, 11:01pm
you've got quite a lot of RC branches in your schematic. Perhaps it would help people answer your question if you specify what these R and C values are. And maybe it would help if we could see the ratio of transistor sizes.
raja.cedt
Reply #5 - Jan 27th, 2010, 5:56am
hi vivkr,
           sorry for that confusing schematic, the RC what i am talking is at the o/p of the 1st stage.
Rajasekhar.
yvkrishna
Reply #6 - Jan 30th, 2010, 11:05pm
hi raja,
i too feel that  your RC n/w at the o/p of first stage is causing this.  what are the values used here?
btw how would that series RC branch compensate your loop ?
regards,
vamshi
raja.cedt
Reply #7 - Jan 31st, 2010, 1:30am
hi vamshi,
              i  have introduced zero at the 2nd pole to compensate the loop..i am not getting what you are asking?
Thank,
Rajasekhar.
Berti
Switzerland
Reply #8 - Feb 4th, 2010, 12:13am
Rajasekhar,
The doublet is at 100Mhz not 100hz ???
raja.cedt
Reply #9 - Feb 5th, 2010, 11:03pm
hi,
  how it won't be at around 100hz,there only i saw some dip in the phase plot.
rajasekhar.
Berti
Switzerland
Reply #10 - Feb 8th, 2010, 3:44am
Rajasekhar,
100hz is just a very low frequency. Therefore without studying you schematic I cannot see how such a low pole should come from the amplifier as Vamishi suggests.
I think it has to be related with the large load capacitance ...?...
Cheers
thechopper
Reply #11 - Feb 10th, 2010, 6:32pm
raja.cedt wrote on Jan 25th, 2010, 8:40pm:
hi tosei,
rajasekhar.
Hi Rajasekhar,
Take a look at this one yourself asked about...
http://www.designers-guide.org/Forum/YaBB.pl?num=1235622483
Best
Tosei
Keep it simple
Trouble viewing this site? Copyright © 2002-2009 Designer's Guide Consulting. 'Designer's Guide' is a registered trademark of Designer's Guide LLC. All rights reserved.
Give back to the Designer's Guide Community by shopping at Amazon. Purchasing products through this link helps to fund our activities and does not increase your cost.
