Quote:You mentioned filtering before I/Q-Mixer.
You mean frequency discriminator using I and Q signals by "quadrature detection" ? Here I/Q-Mixer exists before "quadrature detection".
My mistake...I haven't really got everything figured out yet.
I originally believed I could do a direct conversion (I and Q) followed by filtering, and then limiting, and finally quadrature detection. So the filtering would of course be at a fixed IF (zero). I do understand the difficulty in channel filtering at RF...My primary concern was the filtering since I understand I need to have an SNR of around 10dB prior to limiting amplifier, in order to avoid the threshold effect.
So my main question was should I filter the spectrum in between the mark and space prior to limiting in order to improve the SNR. I'm really actually trying to figure out what
noise BW I should use in order to determine the required NF of the front end. I've concluded that the noise BW in question is just 4*Bmod where Bmod is the bandwidth of the modulating signal (assuming a wide tone separation).
After reading more about the mathematics of quadrature detection, however, I guess that quadrature detection should be done at an IF (not zero), right? In which case I would need some other type of detection.
Quote:If SNR before limiter is fairly large, small signal noise analysis such as PSS/Pnoise is useful.
I'm concerned about when the SNR is around the threshold (10 dB). So does that rule out PSS/Pnoise?
thanks,
Aaron
