https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> Verilog-A : Behavioral model analyzer/optimizer https://designers-guide.org/forum/YaBB.pl?num=1544056720 Message started by AS on Dec 5th, 2018, 4:38pm |
Title: Verilog-A : Behavioral model analyzer/optimizer Post by AS on Dec 5th, 2018, 4:38pm Hello All, Is there an analyzer mode in any spice simulator that can help with identification of simulation speed bottlenecks in Verilog-A models? Thanks, AS |
Title: Re: Verilog-A : Behavioral model analyzer/optimizer Post by Frank Wiedmann on Dec 7th, 2018, 2:06am You could take a look at https://nanohub.org/resources/vachecker and http://www.mos-ak.org/silicon_valley_2017/presentations/T01_Xie_MOS-AK_Silicon_Valley_2017.pdf. |
Title: Re: Verilog-A : Behavioral model analyzer/optimizer Post by Andrew Beckett on Dec 7th, 2018, 4:28am Spectre has an "AHDL Linter". This can be turned on in ADE via Simulation->Options->Analog and is on the Miscellaneous tab. From the command line it's the -ahdllint option. There are some static checks which will then appear in the normal simulator output log, and then some checks during simulation for potential performance issues or improvements (in ADE the Linter log can be shown from the Simulation menu). Regards, Andrew. |
