https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> VCO based ADC frequency domain behaviour https://designers-guide.org/forum/YaBB.pl?num=1524091816 Message started by polyam on Apr 18th, 2018, 3:50pm |
Title: VCO based ADC frequency domain behaviour Post by polyam on Apr 18th, 2018, 3:50pm Hi, I am interested in doing a proper simulation in Spectre to extract the frequency response of a VCO-based ADC. Please check the following figures. A VCO based ADC can be modeled as an integrator followed by a sampler and a differentiator. Can anyone help me to do a simulation in order to get the following curves? It is expected to have a low pass behavior at the output of VCO (let's say ring oscillator). Such a low-pass behavior must be canceled by the frequency response of the differentiator resulting in a flat frequency response. my target is to reproduce such a figure in Spectre. BTW these figures come from "Design of a 5bit 1GSps VCO Quantizer for a CT Delta Sigma Modulator" https://ieeexplore.ieee.org/document/6226117/ tnx :) |
Title: Re: VCO based ADC frequency domain behaviour Post by polyam on Apr 18th, 2018, 3:50pm Freq. res. of VCO-ADC |
Title: Re: VCO based ADC frequency domain behaviour Post by polyam on Apr 21st, 2018, 7:52am Any clue for this problem? Can something be done with Spectre-RF? |
Title: Re: VCO based ADC frequency domain behaviour Post by loose-electron on May 15th, 2018, 10:31pm VCO counter ADC BW is a function of the count period. Typically you do a VCO count for a fixed period of time based upon the sample input voltage, and then do the same time period and get the count when connected to a reference voltage (typically the V bandgap) and then you take the ratio of the two numbers. It is not a linear system simulation, and you generally run the count out to some large numbers in order to average out the inherent (flicker and thermal) noise of the system. I designed one of these for Intel back in the Pentium 1 era for their thermal monitor. These devices are very slow, generally with update rates multiple seconds apart, and the BW approximation can be crudely approximated by the update rate. |
