https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Ideal SH time interleaving https://designers-guide.org/forum/YaBB.pl?num=1501676946 Message started by John Rankin on Aug 2nd, 2017, 5:29am |
Title: Ideal SH time interleaving Post by John Rankin on Aug 2nd, 2017, 5:29am Hello, I would like to use the ideal SH verilogA block to combine the outputs of a time interleaved sampler. I tried doing this by placing 2 of them in a netlist and varying the sample times, but I get an error from spectre : FATAL: The following branches form a loop of rigid branches (shorts) when added to the circuit: I32:Pout_Nout_flow (from net012 to 0) Is there a version of this model somewhere that allows me to sample multiple nodes and combine them into one output? If not, how would you guys recommend modifying the model? Thanks, John |
Title: Re: Ideal SH time interleaving Post by John Rankin on Aug 2nd, 2017, 5:31am Just FYI here is an image of the schematic if that helps understand what I am trying to achieve. |
