https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> AC analysis in spectre https://designers-guide.org/forum/YaBB.pl?num=1494933873 Message started by Gp on May 16th, 2017, 4:24am |
Title: AC analysis in spectre Post by Gp on May 16th, 2017, 4:24am Hi All, I want to run AC analysis of Low pass filter with cadence spectre. With transient analysis, it's working fine But during AC analysis following error generated: ****************************************************** AC Analysis `frequencySweep': freq = (1 Hz -> 100 MHz) ****************************************************** DC simulation time: CPU = 11.999 ms, elapsed = 42.51 ms. Opening the PSF file /home_ei/pdubey_ei/Desktop/gp_test/VAMS_examples/LPF/amscf.raw/frequencySweep.ac ... ncsim: *F,INTERR: INTERNAL EXCEPTION Observed simulation time : 0 FS + 2 ----------------------------------------------------------------- My spectre.scs file is following: simulator lang=spice .AC DEC 5 1 100e6 simulator lang=spectre myopts options duplicate_subckt=warning myinfo info what=oppoint where=rawfile spectre options diagnose=detailed debugstepdrop=yes simstat=detailed debug=yes duplicateinstance=warning duplicatemodel=warning So, Kindly give the solution. Thank you |
Title: Re: AC analysis in spectre Post by Ken Kundert on May 16th, 2017, 9:32am You should contact Cadence when you have an internal error. An internal error is a reaction to some unusual or unexpected condition. To work around it, you should try to identify anything you are doing that is unusual and then get rid of that thing to see if the error goes away. -Ken |
Title: Re: AC analysis in spectre Post by Geoffrey_Coram on May 16th, 2017, 1:32pm I'd get rid of the two options statements and the info, to start (I'm particularly curious about "spectre" as a possible keyword and the name of your second options statement). And I'd re-write your .ac line in Spectre syntax. Not that Spectre shouldn't be able to handle it, but along the lines of Ken's suggestion, eliminate anything weird. |
Title: Re: AC analysis in spectre Post by AMS_ei on May 19th, 2017, 11:42pm spectre doesn't normally use ".ac" since that is the archaic SPICE syntax rather than spectre's own more regular syntax |
Title: Re: AC analysis in spectre Post by Andrew Beckett on May 28th, 2017, 9:53am It's also a good idea to mention which version of the simulator you're using, in case this is a known problem. In this specific case there's not enough information to be going on (it's pretty unlikely that all ac simulations fail because that would be picked up prior to the software being released). However, if you're running an old version of spectre, I'd always suggest trying a recent version just in case the specific issue you're hitting has been solved subsequently. I was able to run an AC simulation using a simple circuit together with your other statements in SPECTRE161 with no problem at all. Regards, Andrew. |
