https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> How can I conver config view in an amsd block https://designers-guide.org/forum/YaBB.pl?num=1489901161 Message started by AMS_ei on Mar 18th, 2017, 10:26pm |
Title: How can I conver config view in an amsd block Post by AMS_ei on Mar 18th, 2017, 10:26pm Hi, I have a big config view in my ams setup in the gui mode. Now, I want to run the same config view in the irun command. How can I convert a config view into an amsd block? Is there any automated script for that in cadence? Thank you. Kind regards, |
Title: Re: How can I conver config view in an amsd block Post by Andrew Beckett on Mar 20th, 2017, 8:12am Probably the simplest approach is to use the runams command to netlist and run the simulation. This will then create the various files you need (you can choose to run the simulation or not). Regards, Andrew. |
Title: Re: How can I conver config view in an amsd block Post by AMS_ei on Apr 19th, 2017, 4:01pm Thank you, Andrew. |
