https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Low Noise Amplifier Design https://designers-guide.org/forum/YaBB.pl?num=1487757249 Message started by prameela on Feb 22nd, 2017, 1:54am |
Title: Low Noise Amplifier Design Post by prameela on Feb 22nd, 2017, 1:54am I am working with a Low Noise Amplifier (LNA) design using gpdk 180 technology from cadence.The simulations are done in cadence virtuoso Spectre in 2-3GHz range at 1.8V supply. I have the following queries. 1. Whether a Noise Figure less than 1dB(simulated) is an acceptable value? 2. I am using simple 'nmos' in the gpdk library. Whether I have to use the foundry library or RF library? 3. For layouting the LNA whether the gpdk library is suitable. ( I have done the post layout simulation of the LNA. But I am getting a negative gain and very high value of NF) |
Title: Re: Low Noise Amplifier Design Post by Hammad33 on Mar 13th, 2017, 10:35pm For your first question, many practical LNAs (good ones) have NF less than 1 dB. So, yes in simulation, an LNA can have less than 1 dB NF. |
