https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Unmet Needs in Analog CAD >> Dummy fill custom tool https://designers-guide.org/forum/YaBB.pl?num=1431532458 Message started by Jeffrey987 on May 13th, 2015, 8:54am |
Title: Dummy fill custom tool Post by Jeffrey987 on May 13th, 2015, 8:54am Hi, Is there some kind of function in virtuoso layout where you can draw a polygon (where nothing else is inside) and get it filled with dummy metal? Can be basic without too much tech file data. like: draw shape, set density, get filled, run DRC, manually remove some errors. Can be usefull in analog circuits where you do manual fill. |
Title: Re: Dummy fill custom tool Post by AnilReddy on May 20th, 2015, 2:17am If not provided by the cadence, may be you can write a SKILL code. |
