https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to generate AM signal in Cadence https://designers-guide.org/forum/YaBB.pl?num=1233850018 Message started by DoYouLinux on Feb 5th, 2009, 8:06am |
Title: How to generate AM signal in Cadence Post by DoYouLinux on Feb 5th, 2009, 8:06am Hi all, Sounds so easy, but I am still not finding any solution to generate an AM signal using Cadence. Anyone tried this before ? Thank you very much, DYL |
Title: Re: How to generate AM signal in Cadence Post by Andrew Beckett on Feb 5th, 2009, 9:20am If creating a schematic, use vsource or isource from analogLib. Set source type to be sine, and enter the main frequency and amplitude. Then click on "Display modulation params", and fill in your AM modulation frequency and index (and phase if you want). You can do the same with the "port" component too. In spectre, these are just parameters of vsource, isource, or port. Type "spectre -h vsource" for details on the parameters. Regards, Andrew. |
Title: Re: How to generate AM signal in Cadence Post by DoYouLinux on Feb 6th, 2009, 8:39am Thanks a lot Andrew for your help :D |
