Modeling >> Behavioral Models >> Cadence Sample Library - cell names??
https://designers-guide.org/forum/YaBB.pl?num=1161615023
Message started by Pavel on Oct 23rd, 2006, 7:50am
Title: Cadence Sample Library - cell names??
Post by Pavel on Oct 23rd, 2006, 7:50am
Hello
In Cadence Verilog-AMS Language Reference there is chapter "Sample Model Library".
In this chapter one can find all the Verilog-A internal primitives with terminals and parameters,
but NOT the NAMES of modules. How could I instantnate them?
For example I need Schottky diode.
In above-mentionned Doc I find the following:
Schottky Diode
Terminals
vanode: anode voltage [V,A]
vcathode: cathode voltage [V,A]
Description
This model is of a diode based on the Schockley equation.
Instance Parameters
area = area of junction
But what is the module name of Schottky diode?
Another question - where in Cadence installation could I find the Verilog-A codes of "Sample Module Library" modules?
Thank in advance.
Pavel
Title: Re: Cadence Sample Library - cell names??
Post by Pavel on Oct 23rd, 2006, 9:09am
OK, resolved.
The primitives are in:
$CDSHOME/tools/dfII/samples/artist/spectreHDL/Verilog-A/
Post by Pavel on Oct 27th, 2006, 1:25am
Situation is more complicated than I thought.
Ok, source code is localized, but can one use it without supplimental library declaraion in cds.lib.
For example how to instantiate nmos, pmos primitives?
I found MOS primitives in $CDSHOME/tools/dfII/samples/artist/ahdlLib/mos_level1.
But when I try insantiate it:
mos_level1 MP #(.length(10u), .width(10u)) MN1
the cell isn't recognized.
What I do - I create MOS cell (veriloga view) in library and copy mos_level1 veriloga code.
But I think it isn't "smart" approach.
So original question persists - how instantiate the primitives from Cadence Sample Model Library.
Post by Andrew Beckett on Oct 28th, 2006, 1:40pm
From your append, it sounds as if you're not putting a reference in the cds.lib - you'll need to do that:
Code:
DEFINE ahdlLib $(inst_root_with:tools/dfII/bin/icfb)/tools/dfII/samples/artist/ahdlLib
(the inst_root_with incantation is to avoid having to reference an environment variable - it finds it in the installation root containing icfb).
Having done that, you should be able to reference it.
Regards,
Andrew.
Post by Pavel on Oct 30th, 2006, 7:52am
Thank you for answer Andrew.
Could you explain me what are resistor and capacitor?
There are no such primitives in ahdlLib library, they don't apear in Verilog-A Keyword list.
Nevertheless I can instantiate these "primitives"
capacitor #(.c(10p)) C1 (A, B);
resistor #(.r(10k)) R1(A, B);
and they are recognized without any supplimental actions.
Best Regards.
Pavel.
Post by Ken Kundert on Oct 30th, 2006, 8:06am
resistor and capacitor are built-in primitives for Spectre.
-Ken
Post by Pavel on Oct 30th, 2006, 8:32am
Thank you for answer Ken.
Where could I find the full list of Spectre primitives with terminals/parameters:
Regards.
Pabel.
Post by bernd on Oct 30th, 2006, 11:00am
In the "Virtuoso Spectre Circuit Simulator Components and Device Models Manual"
<install_dir>/doc/spectremod/spectremod.pdf,
or if you prefer command line help "spectre -h".
Bernd
Post by Geoffrey_Coram on Nov 1st, 2006, 4:09am
Ken Kundert wrote on Oct 30th, 2006, 8:06am:
Ken -
That's only half the answer.  The other point is that "resistor" and "capacitor" are listed explicitly in Annex E of the Verilog-AMS Language Reference manual, which talks about Spice compatibility.  For those Spice primitives listed in Annex E, simulators are supposed to map instantiations in a Verilog-style netlist into the built-in primitives (regardless of whether the Spice simulator calls those primitives by the same names).
For Pavel, it may or may not be useful to see the whole list of Spectre primitives, since some of them can't be instantiated in a Verilog netlist (or module definition) because they require a model (eg bjt, mosfet).  Annex E doesn't cover how one tells the simulator to find the model cards in a Spice-format library file.
-Geoffrey
Post by Pavel on Nov 6th, 2006, 12:01am
In my version of Verilog-AMS Language Reference manual (5.5.1, August 2005) there are no keywords "resistor" and "capacitor"  in Annex E "Verilog-A Keywords". But there are many others, that are just listed, but don't explained. For example cmos, nmos, pmos, rnmos, rpmos, etc...
What they signify, all these keywords?
Regards.
Pavel.
Post by Geoffrey_Coram on Nov 6th, 2006, 6:06am
Pavel wrote on Nov 6th, 2006, 12:01am:
5.5.1 is not a valid version number.  The official Accellera Verilog-AMS LRM is presently on version 2.2, dated September 2004.  In the true LRM,
Annex E is "SPICE Compatibility" and Annex B is "Keywords" and includes cmos, nmos, ... which are explained in the IEEE 1364 Verilog LRM (the AMS LRM was based on the 1995 version of the 1364 standard, which has since issued a 2005 edition).
I'd be curious to know where you got the LRM that claimed to be an official one.  Perhaps you are looking at the Verilog-AMS documentation for your simulator, as opposed to the LRM.
-Geoffrey
Post by Pavel on Nov 6th, 2006, 7:58am
Ok, Geoffrey
I found cmos, nmos, ...  in IEEE 1364 standard.
Concerning your last question, please have a glance on picture.
Regards.
Pavel.
Post by Geoffrey_Coram on Nov 6th, 2006, 12:32pm
So, indeed, you have vendor-supplied documentation.
For the offical LRM, please visit http://www.eda.org/verilog-ams and click on the "Download LRM" button on the left side.
-Geoffrey
