https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Array size function in Verilog-A/AMS? https://designers-guide.org/forum/YaBB.pl?num=1102143840 Message started by mmirmak on Dec 3rd, 2004, 11:04pm |
Title: Array size function in Verilog-A/AMS? Post by mmirmak on Dec 3rd, 2004, 11:04pm I have a simple question regarding determining the size of arrays in Verilog-A and Verilog-AMS. If I have a function which will accept, for example, an array of reals, how may I determine within the function the size of the array? In other words, do I have to pass the array size into my function as an explicit integer variable? Is there some "sizeof" function in Verilog-A or Verilog-AMS which would allow me to determine the size of the array a priori? Thanks! |
Title: Re: Array size function in Verilog-A/AMS? Post by Geoffrey_Coram on Jun 6th, 2005, 8:53am I'm not aware of a way to determine the array size. Since in Verilog (1364), arrays have to be declared using constant_expressions for the address ranges, it seems that one wouldn't need to query the array (it can't grow during the simulation), other than to avoid passing an additional argument. |
