The Designer's Guide Community
Forum
Welcome, Guest. Please Login or Register. Please follow the Forum guidelines.
May 16th, 2024, 1:30pm
Pages: 1
Send Topic Print
DESPERATELY IN NEED OF HELP (Read 4842 times)
lancer
New Member
Offline
Feb 5th, 2005, 6:23am
To whom It may concern,
I am currently in a digital electronics class and we are just getting exposed to Verilog. To test our knowledge of the language, we were asked to simulate logic gates using FET's. Problem is when I tried to design the basic inverter, there seemed to be logical errors even though the syntax was correct. I am wondering if there was something special about using FET's in verilog that I am unaware of.
Right now, all I know is that for nmos, the syntax is
"nmos(data, output, ctrl)" and pmos would be the same except with pmos in place of nmos. Using these , I keep getting the undefined output "z" instead of a logic 0 or 1 for all input configurations and I cannot figure out why.
If anyone can understand what the hell I am saying, please help me out... I am in a serious JAM here.
If it helps, here is code I have so far
module fet_inverter(in, out);
input in;
output out;
supply1 vdd;
supply0 gnd;
nmos(gnd, out, in);
pmos(out, vdd, in);
endmodule
//Test Module
module test_inverter;
reg in;
wire out;
initial
     begin
     $monitor("%d %b %b", $time, in, out);
     in = 0;
     #5 in = 1;
     #10 $finish;
     end
fet_inverter inst_1 (in, out);
endmodule
The truth table this produces is as follows:
Time In  Out
0       0    1
5       1    1
7       1    z
This is obviously wrong and I cannot figure out why............ HELP ME
Back to top
View Profile   IP Logged
Humungus
New Member
Offline
Re: DESPERATELY IN NEED OF HELP
Reply #1 - Apr 22nd, 2005, 12:29am
The proble with you example is that you interchanged the source and drain terminals of your transistors.
Your inverter should read
nmos (out, gnd, cntrl)
nmos (out, vdd, cntrl)
Cheers,
Back to top
Pages: 1
Send Topic Print
Copyright 2002-2024 Designer’s Guide Consulting, Inc. Designer’s Guide® is a registered trademark of Designer’s Guide Consulting, Inc. All rights reserved. Send comments or questions to editor@designers-guide.org. Consider submitting a paper or model.
